Lbz Vs Lly
MGILBERT18
As I am new to the diesel world and looking to buy a duramax truck, I read the specs and see only small differences between the two. I do not see any big differences in the LLY & LBZ. Is major performance difference that the LBZ has been tuned different coming from the factory? If this is true, then theoretically, the LLY could be tuned to basically the same output as the LBZ. If you install an aftermarket tuner, then you should basically get the same output? Any thoughts for a soon to be newbie.
__________________
MGILBERT18
THE NEW GUY FROM TEXAS
all 6.6 duramax's can be tuned above and beyond what they came with from the factory. you will have to worry about the transmissions ability to hold that power though. that seems to be the weakest link in the truck....
as far as lly, lbz argument....
lb7....01-04 ..... 300hp, 520lb/ft
lly.... 04.5-05.....310hp, 605lb/ft
lly/lbz....06-07....360hp, 650lb/ft
lmm....07.5+....365hp, 660lb/ft
06 was a funny year for the lly. it still retained the name of the 04.5-05 model year but included the increased output for 06-07..... the 06 lly also came with the 6sp trans/tap shift option that the earlier lly motors didnt.
I thought the 06 LLY was lower HP than the LBZ but otherwise the same. (just different tuning)
Will the '06 LLY have a "2" as the eighth digit of the VIN? There is still the question as to the out put of the '06 LLY?
I did a google search and what I found said the 2006 LLY was 310 HP but is exactly the same as the LBZ except for the programming.
whoops. those're numbers i pulled from gmfs.com .... i didin't know the difference in output, just took someone else's number for true. :doh:
thanks.
As said before.... 04.5 - 05 LLY's are rated at 310 hp.
06 lly's are rated at 310 hp but are identical - internally and externally - to the lbz
06 - 07 lbz's are rated at 360.
06 LLY's have the black and red duramax emblem and have vin code 2
06 lbz's have the blue emblem and have vin code D
Another note is that all trucks with a ZF6 after 06 had the "LLZ" il call it.
