Richard Hurley
- Messages
- 3
- Reaction score
- 3
I have a 2002 LB7 farm truck that just stopped after running for about a minute. Found no prime. Re primed, would not hold. Replaced filer housing same condition. Checked for noticeable low pressure leaks, found none. Blocked fuel outlet line at filter housing. Prime held fine. From a previous scan i was told i had 4 injectors in the mid 4 range and one below 2. Replaced all injectors hoping to kill 2 birds with one stone. No luck condition still exist. Would it be worth changing the FPR or should i bite the bullet and do the CP3? The truck ran fine prior with no noises, whines or hick ups. Thanks, Richard
