ripmf666
Registered user
<FORM onsubmit="JavaScript: return true;" method=post name=CellHandlerForm action=/si/cellHandler.do> Document ID: 727534 <HR>
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=727534&from=sm#oth1-727534">Engine Block Components
<MAP name=692529.map><TABLE><TBODY><TR><TH align=left></TH></TR><TR><TD align=middle>(1)</TD><TD align=left>Cylinder Head Bolt</TD></TR><TR><TD align=middle>(2)</TD><TD align=left>Cylinder Head</TD></TR><TR><TD align=middle>(3)</TD><TD align=left>Cylinder Head Gasket</TD></TR><TR><TD align=middle>(4)</TD><TD align=left>Valve Lifter</TD></TR><TR><TD align=middle>(5)</TD><TD align=left>Valve Lifter Guide</TD></TR><TR><TD align=middle>(6)</TD><TD align=left>Valve Lifter Guide Bracket</TD></TR><TR><TD align=middle>(7)</TD><TD align=left>Cylinder Head Bolt</TD></TR><TR><TD align=middle>(8)</TD><TD align=left>Cylinder Head</TD></TR><TR><TD align=middle>(9)</TD><TD align=left>Cylinder Head Gasket</TD></TR><TR><TD align=middle>(10)</TD><TD align=left>Dowel Pin</TD></TR><TR><TD align=middle>(11)</TD><TD align=left>Engine Block</TD></TR><TR><TD align=middle>(12)</TD><TD align=left>Engine Block Plug Gasket</TD></TR><TR><TD align=middle>(13)</TD><TD align=left>Engine Block Plug</TD></TR><TR><TD align=middle>(14)</TD><TD align=left>Crankshaft Bearing Cap M8 Bolt</TD></TR><TR><TD align=middle>(15)</TD><TD align=left>Engine Block Plug</TD></TR><TR><TD align=middle>(16)</TD><TD align=left>Connecting Rod Cap</TD></TR><TR><TD align=middle>(17)</TD><TD align=left>Connecting Rod Bearing</TD></TR><TR><TD align=middle>(18)</TD><TD align=left>Connecting Rod Bearing</TD></TR><TR><TD align=middle>(19)</TD><TD align=left>Connecting Rod Bushing</TD></TR><TR><TD align=middle>(20)</TD><TD align=left>Piston Pin</TD></TR><TR><TD align=middle>(21)</TD><TD align=left>Piston Pin Retainer</TD></TR><TR><TD align=middle>(22)</TD><TD align=left>Piston</TD></TR><TR><TD align=middle>(23)</TD><TD align=left>Oil Control Ring</TD></TR><TR><TD align=middle>(24)</TD><TD align=left>Compression Ring (2nd)</TD></TR><TR><TD align=middle>(25)</TD><TD align=left>Compression Ring (1st)</TD></TR><TR><TD align=middle>(26)</TD><TD align=left>Connecting Rod</TD></TR><TR><TD align=middle>(27)</TD><TD align=left>Connecting Rod Bolt</TD></TR><TR><TD align=middle>(28)</TD><TD align=left>Thrust Bearing</TD></TR><TR><TD align=middle>(29)</TD><TD align=left>Crankshaft Bearing (Upper)</TD></TR><TR><TD align=middle>(30)</TD><TD align=left>Thrust Bearing</TD></TR><TR><TD align=middle>(31)</TD><TD align=left>Crankshaft Bearing (Lower)</TD></TR><TR><TD align=middle>(32)</TD><TD align=left>Dowel Pin</TD></TR><TR><TD align=middle>(33)</TD><TD align=left>Crankshaft Bearing Cap (5th)</TD></TR><TR><TD align=middle>(34)</TD><TD align=left>Crankshaft Bearing Cap Bolt</TD></TR><TR><TD align=middle>(35)</TD><TD align=left>Crankshaft Bearing Cap</TD></TR><TR><TD align=middle>(36)</TD><TD align=left>Thrust Bearing</TD></TR><TR><TD align=middle>(37)</TD><TD align=left>Crankshaft Position Sensor Exciter Ring Bolt</TD></TR><TR><TD align=middle>(38)</TD><TD align=left>Crankshaft Position Sensor Exciter Ring</TD></TR><TR><TD align=middle>(39)</TD><TD align=left>Crankshaft Position Sensor Exciter Ring Pin</TD></TR><TR><TD align=middle>(40)</TD><TD align=left>Oil Pump Drive Gear</TD></TR><TR><TD align=middle>(41)</TD><TD align=left>Crankshaft Gear</TD></TR><TR><TD align=middle>(42)</TD><TD align=left>Crankshaft</TD></TR><TR><TD align=middle>(43)</TD><TD align=left>Crankshaft Pin</TD></TR><TR><TD align=middle>(44)</TD><TD align=left>Camshaft Position Sensor Exciter Ring Bolt</TD></TR><TR><TD align=middle>(45)</TD><TD align=left>Camshaft Position Sensor Exciter Ring Pin</TD></TR><TR><TD align=middle>(46)</TD><TD align=left>Camshaft Position Sensor Exciter Ring</TD></TR><TR><TD align=middle>(47)</TD><TD align=left>Camshaft Gear Bolt</TD></TR><TR><TD align=middle>(48)</TD><TD align=left>Camshaft Gear Washer</TD></TR><TR><TD align=middle>(49)</TD><TD align=left>Camshaft Gear</TD></TR><TR><TD align=middle>(50)</TD><TD align=left>Camshaft Thrust Plate Bolt</TD></TR><TR><TD align=middle>(51)</TD><TD align=left>Camshaft Thrust Plate</TD></TR><TR><TD align=middle>(52)</TD><TD align=left>Camshaft Pin</TD></TR><TR><TD align=middle>(53)</TD><TD align=left>Camshaft</TD></TR><TR><TD align=middle>(54)</TD><TD align=left>Engine Block Plug</TD></TR><TR><TD align=middle>(55)</TD><TD align=left>Camshaft Bearing (Front)</TD></TR><TR><TD align=middle>(56)</TD><TD align=left>Camshaft Bearing</TD></TR><TR><TD align=middle>(57)</TD><TD align=left>Engine Block Plug</TD></TR><TR><TD align=middle>(58)</TD><TD align=left>Engine Block Heater</TD></TR></TBODY></TABLE>
© 2010 General Motors. All rights reserved.
</FORM></MAP>
