OK, all, got a problem. I've done a TON of searching on the other place, but just need to bounce some ideas off of everyone.
Long story short, my rig has a knock. It doesn't occur right away, usually after a few minutes of the engine running. It comes on gradually, starting with a single knock, then it goes away, then it comes back for a couple of knocks, then it goes away, then it comes on full strength. If the engine is warm, it knocks right away when I start the engine.
That said, before I go further, I already know that my rig has a bad #2 piston. I had intended to replace it when I replaced the head gasket and discovered it, but I couldn't get the pan off and didn't have the ability to pull the motor.
So here is what I have tried:
#1 - I removed the serp belt to make sure it wasn't an accessory.
#2 - I have thoroughly inspected the Harmonic Balancer and the Balancer pulley for cracks.
#3 - I have managed to crack 6 of the 8 injector lines. I couldn't get the number 4 or the number 8 lines cracked. The engine quiets down a bit when I do, but the knock is still there.
So, after doing all the research I can, here are a few thoughts I have as to what it could be.
#1 - A stuck injector. If it is, what is the best way to fix that? The injectors are rebuilds that a reputable member of both places sold me. They were replaced about 6K miles ago.
#2 - A bad injector line? I know that there is some buildup in the lines that if busted loose can injector issues. When I pulled the passenger head I was as careful as I could be about removing the lines, but it's possible that I bent the lines. If that is the case, is the only recourse to replace the lines?
#3 - Misfire in the #2 cylinder? (Here is a pic of that cylinder)
If it is a misfire on this cylinder, it would also explain the white smoke I see all the time.
If it is either 1 or 2, it is a relatively easy fix. If it is number 3, then I guess I will just have to wait until I can pull my motor and rebuild. I am planning to do so this winter, which will include new pistons and new DB2 IP and injector lines.
What do y'all think?
