Well I got the toy home, a JD 2030, I haven't used it much yet, just ridding around some, replaced all the front bushings & bearings.
When I got it, the motor smoked blue a little, motor sounds good, no puffing from the valve cover vent, no oil leaks, it hasn't been running long enough to tell if it's using any oil yet.
I replaced the injectors with new, still have the blue smoke...
I was ridding around today, got the front back together, and after a while it started smoking worse and almost like it was getting too much fuel and stumbled some for a few minutes then like a switch flipped it went to running smooth again, but still had the blue smoke.
I don't have much experience with these motors, but guess maybe IP might need rebuilding ? I know the other things like rings & such, thinking to try the IP before a motor rebuild...
What say you all......
