gahammerle
Saved by God's grace
Replacing the fuel lines under the intake. I've got some line stamped SAE30R6KX. Is that OK to use?
IIRC, SAE 30 R9 is the viton or equivalent. It's what should be used if you are running any blend of bio, or so I am told. The bio will slowly turn R6 into mush from the inside out.
This is absolutely CORRECT!!!! If you wish to run any biodiesel blends greater than B20, you must have the 30R9 fuel spec hose. The 30R9 fuel hose has a fluoroelastomer liner.
B20 Biodiesel will cause some softening and moderate swell of the 30R6 material, but it should continue to function...
Regards,
I wish to run biodeisel as lube addive thinking 1 gallon per 22 tank, making 1:21 ratio, Tad under 5% any harm in that on stock lines?
Matt -
I don't think that you would ever notice the effects of a 5% biodiesel blend on stock fuel lines. The warnings given in the Biodiesel.org article say only to check for leaks. This would be a result of the hose softening over a period of time (probably > 1 year).
For the ultimate in biodiesel compatibility, the 30R9 spec is the way to go. In addition, the rubber lines (from steel line to Fuel Manager and Fuel Manager to pump) aren't that hard to change, even with the manifold in place.
Regards,
I stuck the end of a piece into a jar of fuel and let it sit for a day. It did not look like it deteriorated any, but I'm gonna leave it sit a couple more days to be sure.
