mangus580
Ok, I have acquired a 95 parts truck for the engine. In trying to start it today, I have discovered it will not flow fuel through the IP. I am presuming that with the lift pump running, and the key on, I should get a nice steady stream of fuel out the return port.
I have removed both the return and intake fittings on the pump. Attempted to blow air through (which nets a MINOR flow out the return). I have had the shutoff solenoid off to verify that is working properly.
Nothing!
So... any ideas? The truck has sat for about 5 years. The fuel doesnt smell the 'best'. Am I up against just swapping the pump with another one? (have a couple spares)
Sux that I have to swap the pump to even make sure it runs before I yank it to put it in the new Burb...
Nothing!
