dur0maxx
Is Blowin Soot On A Prius
I installed VDO boost and pyro guages yesterday. I tried so hard to get the fender out so I could get to the area needed to drill and install the thermocoupler but it just would not come down. So instead I put it in the front area of the manifold right before the turbo. I will take pics of it when my camera finishes charging. It is right under the compressor basically. Is that ok or did I make a way bad decision on putting it there. My guage is working and showing me temps.
On a good note, after putting in the boost gauge I finally got to see how much boost I was running since the TM install. I am at 7psi WOT so I think that is way good for a guestimate on adjusting the TM without a guage. I think I'll keep it there until I get a PCM.
