We kind of just follow the lead that others have tried recently with these pumps to increase the fuel flow (volume ). The housing of similar DB2/DB4 pumps are the same size. The head (rear-most section), which the lines attach to, is the fuel distribution. The rotor, which the plungers are in, is the high pressure section and fuel is just transfered to the head, by the matching up of corresponding ports as the rotor turns. The rotor from a DB2 and DB4 are the same size and interchangeable, the fitting with the head is very close tolerances though and Stanadyne usually only sells the head and rotor as an assembly. I believe 6.2turbo has used a 4 cyl rotor (larger plungers) with one of our 8 cylinder heads and body. The 8 cylinder head, AFAWK, was only used with the GM and Ford automotive applications. The 4 plunger pumps, were used in many applications, but as of yet have not seen any with the plunger size above .310". Even with the .310" plunger in a DB4 pump, two of the plungers are sometimes bevel cut for clearance issues. We have more Stanadyne data coming, in which we will be able to compare parts #'s, to have a better idea what all was changed between one pump and another.
This is getting a little off thread direction, if someone would like to start a DB2/DB4 mod specific thread, we will participate and share all the info we have. In this, there are those whom have tried many more things than we have and we will be able to learn much more.
