Will L.
Warning bumped my head again and got to thinking...all insults welcome:hihi:
So I watched a rerun of mythbusters about blowing manhole covers 50 feet in the air. The jest of it is with clean passages the flame front could barely pop off the manhole covers, but with a bunch of obstructions in the way it had a massive increase in flamefront and of coarse increase in power. I didn't find a video of the small test that shows it, but here is a caption:
For small-scale testing, Adam and Jamie built a miniature sewer pipe fitted with a full-length viewing window and three manholes. They pumped in enough methane to reach a 9% concentration in air (the center of its flammability range) and used a spark to set off the mixture. A test with both ends of the pipe open gave only a small flash of flame; when the ends were closed, all three covers flew off. The addition of metal debris to the pipe, simulating junk that might collect in a real sewer, launched the covers even higher due to a faster, larger flame front moving around all the obstructions.
I cant help but wonder about some type of slinky / stainless steel brillo pad , or some perforated steel in the top of the chamber magically glued to the head, of coarse avoiding the valves and cylinder walls.
At Timet they make titanium, and there is this stuff called sponge. Its a very porous state of the metal being formed - something like that if anyone is familiar with it in a foundry.
I did some play with a simple pipe and gas fumes tests with sos pads and wow. I am years away from being able to put this to real experiments with scrap engines to break. Just thought I'd throw this out there for any one in a playful mood.
