Pillow
Recruit
Idiots!!! Why did the brain trusts at GM design the ignition switch and wiring to use these impossible E-0 (?) heads on the retaining bolts? The "E" series is essentially a reversed Torx.
The actual wiring was not that bad at all... Maybe I was mentally prepared for hell
BUT I of course broke the PLASTIC ignition key actuator disk with the male nipple in the middle... Hopefully some Super Glue will do the trick, but I doubt it. Looks like the dealer might see this truck again in its lifetime after all, as I am a little stuck on how to fix that one.
... Friggin pissed on this project and in seeing the cheapness of parts that actuate the ignition. Why not metal? Why not a less convoluted system? Why such a rediculous bolt to keep it together?
Grrr.
Grrr.
