heard its a PITA, gotta remove A/C pump, coolant line, PCV line, then remove the 3 torx-25 screws holding it in without dropping them into the valley.Put 2 QTs of a good trans fluid in the tank with the next fill up. After about 1/2 tank is used see if it is any better. This helps the lubricity in the fuel. You may be getting a gall on the slide inside the regulator. This will help loosen it back up. I've moded them sinse 05. I've seen this condition many times and this usually helps.
The info is right here before your eyes.
DO IT!
