brokenmotor
I don't know diesel
My 6.5 is new, as in it has a couple thousand km on it. My water in fuel light flickers sometimes, but it will go out if I press on the brake, and I have seen it flash with the turn signals opposite the timing of the turn signal flash. When my hazards are on, they stop flashing and stay lit if I press the brake.
The truck started dying on me yesterday at basically idle speeds or very light throttle, and if I put it in neutral and start it, it starts right up, and if I accelerate hard, it seems to run fine. The problem seems to be getting worse, because I could not back into my parking spot at an idle last night, as it kept stalling. I would start it up in neutral with my foot on the brake, and then when I went to shift into reverse,it would stall. I cleared the computer yesterday, and when I got home last night, I had codes 32 33 and 35. I think that I may need to do a better job on the grounds that come from the firewall harness to the intake........Perhaps....
Thanks in advance...
