Sparky8370
Do chickens have large talons
I went to get gas to mix the other day. I put the can on the ground then I heard a dog in the car next to me. So I started talking to the dog and next thing you I look at the pump and see 9 gallons pumped already and look down at an empty can. I turned around and sure enough, just out of habit I put it in the tank after I distracted myself playing with that dog. So I pushed my truck to the corner of the lot and had someone bring me fuel cans and bring me to the auto parts store. I bought a holley 110gph fuel pump, some fittings and some hose. Oh and a thing that had a cigarette adapter at one end and battery clips on the other. I got back to my truck and cut off the cig adapter and wired the clips to the pump. I took the supply hose off the filter housing and attached it to the fuel pump. I pumped it all out until it was just spurting. Then I put 10 gallons of diesel in and pumped it until it came out clean and steady. I put everything back together and drove over to the fuel pumps and it died. That's ok, I planned on that. I was waiting for the air bubble to get to the filter housing so I could bleed it without losing a filters worth of fuel.
It actually runs better now. It was smoking at idle a lot. Now it has to be idling a lot longer. I'm thinking the fuel pressure is slowly leaking down.
