I need a good FFM or a rebuild kit.
I have the Stanadyne filter (metal top), big filter lock nut and Viton orings in stock. I can get the heater. Not sure what else you might need. I even have a used FFM housing. Let me know what you need.
I know at least one had the heater leaking. I haven't looked at any of them in some time. I know they all leaked when I swapped them out. I just can't remember what was leaking on each. Or even which is which anymore.
What are the possibilities?
What does a complete rebuild kit with heater cost for one of these?
If you send me your core I'll rebuild one I have with,
New heater.
New Stanadyne filter.
New lock ring for filter.
Viton Orings.
Sandblast & paint.
For $148 shipped.
Core charge $80.
Optional, Fuel Pressure Tap $30
Optional, I can drill & tap inlet for 1/4 NPT $10.
1/4" flare swivle fitting to 3/8" barb $15.
Simular to this.
Right now I have 3-5 around here, so would'int need any cores at this point. If you have an old crank pulley I'd take of a few$.
I'll look for a crank pulley. I would think I would have one here someplace - should have 4 if I didn't scrap them. I have one on the 94 if I ever get to installing the Fluidamper on that truck. I'm not sending you the Fluidamper instead.
