bigchevy89
what are you gonna do for the upper plenum as my did not line up correctly.
You must be using the HX40 not the HX40II it lines up perfectwhat are you gonna do for the upper plenum as my did not line up correctly.
ok mine was about a half inch off what is the diffrence?
iam pretty sure the the compressor housing says 40II ill check tommorow
Very nice looking.
Except for the bent fender lip and bright colors, it looks like it could have come that way factory.
What were your boost levels like at this 200f lower?
Comparable to a gm8? Higher? Lower?
I spun the rod 4 turns to make sure the boost wasn't too high out of the gate, it peaked at 15 psi 850 F, WOT
Really.
Now I'm much more interested in your results (egt, black smoke, boost levels, etc) when you put this through a "test loop".
I also think you should start thinking about a price for an "install kit"...
Exactly, thats what this is all about, im gonna put a couple hundred miles on it before I really push it, If it all goes good then I will push forward with the Kit
Could this be a difference in the quality off the chinese manufacturing? Since the chinese stuff isn't noted for it's perfection....
Very nice looking.
I like the use of the "T" clamps.
The down pipe pic makes it look like there is a bit more room to work the radius a little bit more gently. But that might just be the angle...
