racedaymechanic
Active Member
I figured I would start a new thread, anyway this what I have come up with for the HX40II, Its pretty simple and should work with all airboxes, Just need to try it out
Do you tighten the nut on the controller to increase boost and loosen the nut to decrease boost, is it the less the spring is being compressed the less boost i will have.
I havent tested the new spring rod setup yet but I was able to get down to 10 psi and 20+
