HX35 Boost issue
BigBearZach
Eglin afb
Ok i recently instsalled an HX35 turbo on my truck and i think i may have an issue that is i can only get 15 pounds of boost out of it. Now i know from others with this kind of turbo the can get up to 30 to 35 pounds so why will mine only make 15.
If you have a stock tune it will defuel like no tommorrow once your boost approaches 15 unless you have a resistor or 3 bar map installed.
I have hit 18 with mine, then turned it down to 13-14 psi. max. I have a WH1C, basically same thing. A chip will help that setup a lot!
Have you checked for leaks at the crossover pipe connections? Leaks at the crossover joints will hurt the ability to make max boost.
