racedaymechanic
Active Member
Here is the new setup for Oil drain, The lines are crimped and its PTFE Lined hose, Tig welded Bung in the fuel pump plate, this is all you need to cure the oil drain problem, It will be included in my Kits for the HX35/40II and the New kit for the HX40 also can be bought separately for $135.00 Shipped
