I meant to type A6 in my last post for the 1988 Suburban. My memory from 20-25 years ago may have faded or the 1988 had non-factory aftermarket air installed as AC wasn't standard back then. I checked our supporting vendor catalog Rock Auto to confirm that Factory Air did not use the A6 for 1987 or 1988.
The average backyard mechanic really shouldn't be messing with their AC system unless they have a $4000 Refrigerant recovery machine or hire the recovery step out to a shop or friend who does have one. Further the FOT (CCOT) systems are charged by weight only. Dropping a $50.00 fix it R134a can on their system leaves an unknown charge in the system. The correct way is to recover, vacuum, and recharge the system with leak check and/or repair somewhere in the steps depending on the situation.
The charge by weight is specific to the FOT system. Systems leak and the charge will leak out over time no matter what. So when in doubt, recover, vacuum, recharge, and leak check.
Now the graduate level course I am talking about here and this course is VERY specific as to why you charge the system by weight. This is not general theory! This is taking some little known information from the folks that developed the CCOT system, why you can't know this specific design system charge accurately enough by pressures and temperature, and failure analysis of the R4 vs. other compressors with a bulletproof reputation.
First off we need to understand WTH the suction accumulator does. It's location in the system is between the compressor suction hose and the evaporator. Contrast this to the expansion valve systems that have the receiver/dryer between the condenser and the expansion device.
The accumulator's primary job is to separate liquid and gas. It's name isn't so much from "suction accumulator" as it is from accumulating the unused system charge in liquid form. The system charge changes with heat load, condenser temperature, ect. It also holds a leakage reserve. Again I am repeating the cool-profit link.
The 5-10% of the total refrigerant flow out of the evaporator being liquid is when the system is properly charged by weight. The accumulator's job is to make sure this liquid refrigerant doesn't make it to the compressor, but, it has to return oil. The oil return is accomplished by a liquid bleed hole in the suction line pickup tube in the accumulator. Any system overcharge winds up in the accumulator, as well as the leakage reserve, and a varied amount for load changes. You don't get much error in overcharge that the accumulator can hold before liquid can reach the compressor - in theory as likely the high side safety switch would trip the system off first followed by the high side pressure relief venting the system. (Or the high side simply blows up like the 1993, Patch, was known for with a bad high side switch.)
The 5-10% of liquid refrigerant leaving the evaporator must evaporate as the book link explains the heat comes from gas leaving the evaporator. I'll mention some heat through the walls from the hot engine compartment, but, some are insulated from the factory so this isn't the primary heat source.
Now as to oil flow - think of drinking through a straw. It's all good till you get to the last of the drink and have to suck a lot of air to get the last of the drink out and hope you don't inhale it and cough. This be the two ways to move oil in the AC system. By liquid refrigerant or gas velocity carrying it along. The evaporator is "boiling" and uses a messy combo of both methods to move oil in the small tubes.
The accumulator uses the bleed hole to move oil otherwise the system oil charge would all wind up stuck there. If gas alone moved the system oil well enough there wouldn't be a liquid bleed hole in the accumulator as it allows the suction pipe direct to the compressor to fill up with liquid when the system is off.
To be clear for the quiz: The suction accumulator has liquid refrigerant in the bottom of in a properly charged running system.
And a good explanation with cut away picture is by cracking a book:
Fundamentals of Automotive Technology
By CDX Automotive
https://books.google.com/books?id=m...Accumulator ccot Accumulator cut away&f=false
