Husqvarna Model 55 (15yrs old) taking off clutch/drum to access drive sprocket
schiker
Pendleton, SC
Are the threads to take off the clutch / drum and access the drive sprocket (they call it a ring) a left handed thread ?
I have the piston stop tool but never taken one off. It seems pretty straight forward take sparkplug out rotate to get piston down or up to approx correct point install stop. Turn slowly until against stop then torque off nut/clutch.
If I am thinking about it correctly the crank is trying to loosen on the nut while cutting. Seems a good candidate for left hand threads. Or is it just a nut and the the clutch is keyed to the crank and can't relatively rotate such that left hand threads are not beneficial.
I assume should change needle bearing, clutch drum, and drive ring or sprocket all together.
This is my brother-n-laws saw and I think when the sprocket went the chain chewed on the clutch drum sprocket area a bit. Note I have a model 51 Husky and am letting him borrow my piston stop tool. Thought I'd warn him they might be left hand threads.
I'm pretty sure they should be LH because the saw is trying to unscrew it. At least I know that of the 4 different brands of saw I've had, 3 were LH and the 4th I don't recall but I'll bet it was LH.
