Howdy Folks!!
txroadkill
Mike here from El Paso. New to me 1993 C3500 DRW, 2WD, 6.5L, FASS and NV5400.
The fast idle solenoid has been removed as it is very much broken.
Truck idles high 2K-ish or better. Runs good otherwise.
Anybody have any ideas on how to fix this? Any adjustments I can make?
Thanks in advance
Welcome @txroadkill nice looking rig. looks like the screw end on the idle solenoid is badly bent. mine was bent but not as bad. if your very careful you can try to slowly straighten it out to the point where it will slide in and out freely. then reinstall on the IP, send 12v power to it and adjust where you want it. this solenoid is for the cold start warm ups. on my truck I tied into it with a one way diode and ran it to a relay that controls an aux cooling fan for my ac. this way when I have the ac turned on the idle is up a touch. it helps when sitting at a traffic stop in this blazing Texas heat!
BTW it's nice to see another fellow Texan here in the forums :)
How much fuel pressure do you have? And you can pull on the leaver, could be your throttle cable is too tight...
I thought that too but i can loosen it up and it changes very little. I tried turning out the hex screw on the IP and it changed nothing as well. Could the IP timing cause that? I had the IP off and cleaned it up hoping that was the issue. No dice. This is super frustrating. And now I have a fuel leak in one of the injector fuel return lines so I'm down until the kit comes in. Freaking sucks.
