How to remove the front drive shaft from a NP 246 transfer case.
jrsavoie
Recruit
Rural Clifton, Illinois
Do you cut the clamps on the rubber boot and slide it apart?
Does anynody have any pics &/or instructions for removing the front drive shaft from the NP 246?
Any I've seen, you take the 4 bolts out of the flange on the transfer case and the 4 bolts out of the yoke on the front differential.Compress the shaft by prying it out of the front diff. No need to take the shaft apart.
This must be a 1998 and newer thing or 246 transfer case specific. no bolted flange from the transfer case. All the other transfer cases I had were as you described.
My newest service book is a 1996 so it didn't show anything applicable.
Why do they take something that works and change it?
