How to remove injectors... JD 2030
Twisted Steel Performance
Vendor
Pauline, SC
Do I need a special tool to change the injectors on a JD 2030 diesel motor, I bought 4 new inj, do I need any seals or anything when I install the new ones?
How do I clean the hole they slide down in?
I have one that is leaking compression when running, the clamp is broken so I also bought new clamps also....
What else will I need to purchase along with the injectors to finish the swap....
not sure if this is the same engine but it sounds like the same style injectors also if you want a better pic pm your email
Thanks Les, found the cleaning tool online... 170$ + the ride.... Wonder if a rifle bore brush would work, the holes around them aren't very dirty?? I found a tip on a tractor forum that said might loosen the clamp bolt and turn it over and maybe the compression might blow them loose??
I used a narrow blade wood chisel to scrape the inj seat clean and hit the starter to blow the carbon out.
You can use a plumber brush to clean the bore.
An injector puller/slide hammer can be made from a fitting nut, a long bolt and a piston pin for the slide weight.
