Here is the next chapter in the continuing saga.
I treated the rust with wire brush, naval jelly, rust reformer, and rustoleum. When I came into the house after wire-brushing the rust, my wife told me I looked 10 years younger. The rust dust covered the gray in my hair...
I reassembled the brakes, using new parts. I installed the wheel cylinder while the backing plate was off. In order to have enough room to work, I connected the brake line before installing the backing plate bolts. The backing plate comes on and off simply enough. I'll never again try working behind it without first unbolting it and sliding it a few inches down the axle. There's simply not enough room back there for someone with large hands to work.
I have some questions, and I'm having trouble with the parking brake cable. First, some pictures of what I did:
Here is the backing plate reinstalled with the parking brake cable and the new wheel cylinder. I couldn't buy wheel cylinder bolts that would match the old ones, so I bought longer ones and cut them down to length. I used stainless bolts this time, in hopes of avoiding the corrosion problems evident in the old bolts.
Here we have the parking brake lever, its clip, brake shoes, adjusting screw, and the first spring in place.
The parking brake transfer bar and its spring fell out several times as I struggled to get all the parts in place.
The self-adjusting mechanism and the nails and springs that hold the shoes to the backing plate:
The rods that connect the shoes to the cylinder, and the remaining springs:
I'm pretty sure I have all the parts installed correctly, but I have questions. First of all, the rearmost shoe sits much closer to the backing plate than the foremost shoe. Is this normal? I wonder if I have the springs reversed. The green spring I installed on the back nail is longer than the yellow one I installed on the front nail. The green one has a bit of a taper that seems designed to fit into the cup formed by the self-adjusting arm's pivot...
Left picture is front of brake.
The parking brake bar touches the backing plate in the rear, but it's about 1/4" away from the backing plate in the front. Is this normal?
And finally, my parking brake issue: Remember, my problems started when I paid $300 to have a new parking brake cable installed, so the truck would pass inspection. I had to go back twice because "GM sent the wrong cable". I wonder if they just installed the wrong cable, causing my problems. Now, I can't get the cable back together. Before disassembling my brake, I disconnected the parking brake cable below the rear passenger door, as it says in the manual. To re-install it, I had my middle-linebacker son push the brake lever forward while I pulled the cable. I could not get enough slack to reconnect the cable. Yes, the foot-pedal is disengaged and all the way up.
If you guys can talk me through fixing the parking brake, that would be great. Or maybe I'll tie up the loose ends of the parking brake cable and take it back to the guy who "fixed" it before. In that case, I need to reinstall the drums & wheels, & bleed the brakes. I also need to clean and lube the bearing, install the new seal, & top off the diff lube. Have I missed any steps?
Do you folks see any problems/issues in the assembly so far?
Thanks again,
-jpg
