Max Attitude
Typical White Person
I just did this on a 2000 Chevy 1500. I believe all the '99-early '07 trucks are relatively the same. It's easy so save yourself some money and do it yourself. I'll do my best to explain step by step. I bought my aftermarket window motor assembly from a parts store. $116....about half of what the dealer wanted.
First gather the tools needed: A utility knife (or any knife), 7mm nut driver, a regular screw driver, a 10mm socket, ratchet driver and extension, and of course the window motor assembly-
First take the door lock switch off. It pops right out with a screwdriver-
Then take the triangle panel off. Put the screwdriver in the 2 spots marked and pop it off-
Then take your 7mm nut driver and take 2 screws out. One is on the bottom of the door panel-
and one in by the door handle-
Now that the bottom screw is out take the storage compartment out-
Once the storage compartment is out unplug the light on the door panel-
One more thing before you can pull the panel off. Put the screwdriver at the end of the door switch panel and pry it up carefully. Then remove the 7mm screw and unplug the switch panel and set it aside-
Now you are ready to take the panel off. Lift it upward by the handle and the bottom of the panel. It make take a little wiggling. You will have to fish the door handle through the hole.
Now that the panel is off you will see a plastic covering. First make a cut in the plastic in front of the handle-
Then unbolt the handle from the door using the 10mm socket.
Pull the plastic off of the door and the handle will go through the hole you cut in the plastic. Set the plastic where the adhesive won't get dirty.
Now you will see the motor and where the bolts are located. I don't have pics of the bolt locations, sorry. But one in the pic is circled-
I think there are 8 10mm bolts total, 4 on each side including the part that clamps the window. This is how the window motor assembly looks when removed stock on the left, new aftermarket on the right-
First unbolt the window clamps, you can see them through the door holes...they look like this-
Once you have it unbolted make sure the window stays where it is. The one I did stayed fine but you make want to take a screw diver or 2 and position them so the window stays up.
To take the window assembly out you just take the 2 sides and put them together to the bottom of the door and pull out through the opening. It's hard to explain but you'll figure it out. ):h
Now just reverse each step. Piece of cake. :thumbsup:
Any questions just ask.
