How much for a rebuild on a 4L80E?
jrsavoie
Recruit
Rural Clifton, Illinois
Jorge6.5
I had mine rebuilt
Registered User
Join Date: Jun 2009Location: Upstate New YorkPosts: 281Member #: 2863
i had mine rebuilt
$995 in and out on a 4X4 plus hard parts like gears, bearings and electronics. Clutches, seals, and bands included.
Allstate Transmissions in Phoenix.
I pulled the tranny myself and brought it to the shop was quoted 800-$1000 for a full rebuild
Cost $1000 because my od drum was fried, bought a billet piston converter from Transtar for $275 us core, transgo hd2 reprogramming kit for $120 installed by tranny shop, new Hayden fluid cooler and new lines for about $100 and I also decided on new converter to flex plate bolts from arp for $22
I just did a Th400 for my nephew, which shares many parts and design with the 4Le80. Master kit was $200 and did not need any hard parts or converter.
I just got mine back together,did the internal dual feed,and added one more clutch and steel to the directs.
i didnt have time to do it so they did the R&R.. didnt need any hard parts but i was an a** and ordered all the electronics from gm i mean all sol, pressure sensors wirimg harness gov motor and a dayco converter..1400.00
I have been burned by the el cheapo eletronics from a tranny supplier china junk..
They're of similar origins...but with no disrespect intended, implying a TH400 and 4L80E are alike is kind of misleading. Just like a TH350 and the 700R4/4L60/4L60E series have their similarities, the OD transmissions are far more complex and expensive to build. Most shops can knock out a TH350 or TH400 build for a couple hundred bucks, but once you get into the OD transmissions, you're usually hovering around a minimum of a grand, regardless of whether it's the light duty 4L60 family or the heavy duty 4L80E.
Richard
Stock is 5 clutches in the direct drum,and forward drum. They can hold 6 by removing the wave plate,and using different thickness steels. I have only 5 now with the turbo 400 direct drum. Some people machine the pistons,and top plate for more clutches also.
