How many here use this stuff?
It is a good diesel additive! Many use it with no problems. It is very similar to Stanadyne! It provides a good dose of cetane boost to the fuel to make it burn more efficiently! It will keep your injectors clean too!
I have used it for a long time. Started using it in my '05 and have used it in every tank since I have had my '06. White bottle in the winter and silver bottle in the spring and summer. I use 8oz ever fill up. Some times more in the winter of the winter blend to make sure the fuel keeps from gelling. I think it works pretty well. I never have had a problem with fuel gelling since I have used it. Might even gain a MPG or two.
I use the regular Power Service all the time and throw that stuff in every once in a while.
I use it every fill up with this low sulfur fuel now.. so far so good..
Same as 12ga for me. Over 100k miles with the PS products and I'm quite pleased with the results.
I use it off and on. Try to put some in every few tankfulls. I swear the last time I put it in, my mileage seemed to go down about 2mpg. Anybody else had this happen?
Mine only goes down if I DON'T add the silver bottle... (per given same driving conditions)
Nah, never have seen it go down with adding it in the tank. I use a little more then what is needed, but it doesn't hurt either, and it seems to help. Going off of my '05 Dmax, before I started using it to after I started using it, gained around 1-1.5 mpg. Can't really go off of too much the '06 I have now, since I have used it in every tank since I bought it. I always suggest to people to use a little extra of the winter blend if you are in cold temps that time of the year. 8-10oz every fill up and I can all but put gelled fuel out of my mind all winter long.
