Dont know why, but the turning signal (driver side) no longer works, I assumed it was the bulb that went out but the bulb is still fully operational upon checking.
The driver side turning signal (and consequently hazard lights aswell) do not work and I dont know why.
View attachment 99907View attachment 99908
Most likely bulb connection within the bulb socket, or, socket itself is not making a grounding circuit.
Hook the alligator clip of Your probe tester to a good grounding source. Probe the metal bulb socket, faulty lights turned on, if the test lamp lights up then its a bad grounding circuit.
If the lamp does not light, then probe the individual contacts within the bulb socket.
A little known bulb socket cleaning method is one of those round wire brushes used for cleaning inside of copper pipe before the soldering the joints together.
Hardware stores usually stocks those. I keep several of them in my parts cleaning components bucket.
