Correct - both posts define correct methods for glow plug testing
Also, while you're at it, note the condition of the glow-harness wiring and connections:
- female connectors must fit tightly onto the glow-plug spade terminals - high clamping tension ensures full-current electrical connection - loose terminals mean reduced current, minimal glow
- frazzled, broken wire conductors or\and loose crimp means reduced current, minimal glow
- damaged connections\connectors give same results as damaged\failed glow-plugs
To restore correct spade terminal tension, get ur automotive dykes outta the toolbox, use a small jeweler's screwdriver to remove the plastic insulator, observe the as-found spread in the slot that slips over the male spade:
(Place prerequisite precautionary note here):
- now, it doesn't take a brain surgeon to do this, but those, or similar, skills would help: Hulko, the ham-fisted 18-wheeler wrench, is gonna quickly destroy the connector, and prolly the dykes, to boot - Joe, the mechanic, will also likely have problems with this delicate procedure
- look inside the connector insulator at the female spade terminal - you'll notice an upset tab in the terminal which locks the plastic insulator - using the small screwdriver, depress that tab to release the insulator, remove by pulling forward off the terminal
- note that the spade female is constructed of a flat piece with ears, each side ear folded back over the center to form a wide slot - those folded ears spread open with age, heat, and removal\reinsertion, reducing tension required to make proper electrical connection
- now, using the dykes, gently compress each side-edge of the terminal, reducing the depth of the spread - make the folded ear sections closer to the main body
- test the fit after each sequence - female connector should be a tight, secure fit on the male spade
- when so, bend the securing tab out enuff to secure the insulator, insert the terminal into the insulator, and yer good to go
