RNation
I have an 84 Suburban, 3/4 ton, rear wheel drive, 6.2 motor. I'm pretty sure the torque converter is about to crap out. I called O'reillys to get a price on a replacement and they need to know which transmission I have. So is there a way to tell by looking at it? Mine has overdrive if that makes a difference. Also, I put a drop in motor in about a year ago, same motor but it was from boyces (something like that) where they take it out of military vehicles. But I had to switch the flywheels to get it to work (flywheel that came with the drop in motor didn't work, so I had to use the one that was on the original motor) so maybe if I knew what transmission the military vehicles had (400 or 700) I could figure mine is the other one. Any ideas?
