I changed out my lift pump with a higher psi one I found. I had to find another place to mount it because it was longer so I used the bolt under the cab coming through that holds the drivers seat down to mount Lp on. (didn't want to cut any of the fuel lines till I got the bugs worked out) Took it for a long drive and noticed a big difference but when I got home and checked it the LP was hot to the touch? Do they get that hot? I have never noticed and that bothered me that it was hot. The new pump looks the same as the stock lift pump just delivers more psi 10-14 instead of 6-10. Long story but wanted to explain it in case where I mounted it is a bad location and could be causing it to be hot.
