Honda 200m Starter problems
HoytBows
Ex-Michigander, now Elizabeth Colorado
Alright guys I didnt know where else to go with this thread but I think the starter on my trike is bad I had it apart and cleaned the brushes and put it back together and tried to start it. And it worked great for a minute. The next time i went to turn it over again it wouldnt go and started smoking. That was the original problem as well, it didnt want to turn over, but the smoke was new.
I found a site that i can get replacement parts for the starter, but i have no idea which parts i need or what went wrong with the starter since when looking at it, it seems fine.
fields are attached to the outside of the housing, windings are on the armature which spins inside the fields and is part of the main shaft.
sorry man this still isnt hitting home. What is a field and what is a winding, what is their purpose and what would make them not function properly. I think i might have a guess what the windings are the way you describe them but I need a little more direction...
Get a brush kit from Honda. Using the directions provided by AK, resurface the commutator and undercut as stated in fig. 6 and test the armature. Reassemble making sure it's sealed properly. They are not that hard to rebuild and I've had good luck (20-30 or so) with them lasting for years after a proper rebuild. I use to have an ATV repair business.
