mgray
I've only owned the truck 2months less a year. When I first bought it, the rear pax side brake assembly was caked in sludge, apparently from gear oil mixing with whatever. Replaced both side seals. Apprx 5000km later I noticed (could see spray and smell it) rear drivers side seal leaking. Fixed it. Approx 5000km later center seal leaked (oil sprayed up under bed). When fixing it, noticed both sides were wet. Fixed all 3. 2 months later, sides wet again!! This time tried GM seals. Now...about 5000km later...
Changing engine oil, thought I'd check the rear diff level. Low! Slight dampness seen thru brake adjustment hole. No spray noticed in the wheel well or smell though. Center pinion seal seems to be seeping still.
WTF???!!!! Breather is NOT clogged.
Using 80w90 and I have a G80 code, don't think anything's been swapped.
Ideas? Thanks
Ideas? Thanks
