HID conversion kits
ak diesel driver
6.5 driver
alaska
This was posted on my local CL.
It is illegal to covert headlights
there is a $10,000 fine for any shop converting headlights.
Update: May 3, 2007:
NHTSA Cracks Down on Aftermarket HID Conversion Kits
The National Highway Traffic Safety Administration (NHTSA) is targeting high-intensity discharge (HID) conversion kits for enforcement actions. NHTSA has concluded that it is impossible to produce HID conversion kits (converting a halogen system to HID) that would be compliant with the federal lighting standard, Federal Motor Vehicle Safety Standard (FMVSS) No. 108. The noncompliant kits frequently include a HID bulb, a ballast, an igniter, a relay and wiring harness adapters. The NHTSA believes this equipment presents a safety risk to the public since the kits can be expected to produce excessive glare to oncoming motorists. In one investigation, the NHTSA found that an HID conversion headlamp exceeded the maximum allowable candlepower by over 800%.
Under FMVSS No. 108 Section S7.7 (replaceable light sources), each replaceable light source for headlamps must be designed to conform to the dimensions and electrical specifications for the headlamp source it is intended to replace. For example, if an HID kit is marketed as replacing an H1 light source, then it must match the H1's wire coil filament size and location, the electrical connector size and location and the ballast design for use with an H1 light source (which is impossible since there is no ballast). Consequently, companies that are manufacturing HID light sources (e.g., D1S, D1R, D2S, D2R, 9500, etc�) with incandescent light source bases (e.g., H1, H3, H7, H8, H9, H11, H13, HB1, HB2, HB3, HB4, HB5, etc�) should be aware that this light source design would not be one that conforms to FMVSS No. 108, and could not be imported and sold in the United States without violating Federal law. (The importer is treated as the manufacturer and subject to the same fines and penalties that apply to a domestic manufacturer.)
NHTSA has also determined that a commonly used disclaimer "for off-road use only" has no legal meaning and is not recognized by the agency as the manufacturer, importer and retailer are not in a position to control use once a product has been sold. Any equipment offered for sale which is covered by FMVSS No. 108 (headlamps, taillamps, side markers, etc.) must comply with the standard.
Its impossible to enforce. Its a federal law, not a state law. No county, city, town or even state law enforcement agencies can enforce a federal law. State agencies have no authority over federal rules and regs. Besides, the federal gov't has no traffic laws. The closest thing they have is DOT laws. Its up to the individual state to assimilate something that reads close. So unless it miraculously becomes a state statute in all 50 states, there really is nothing they can do.
Worst case scenario is you could fail inspection, if your state has inspections. Then again, most states with inspections accept out of state inspection requirements so it'd be valid to cross the state line, get it inspected and go right over to the DMV to reregister...
Plus, that ruling says the shop gets fined, not the individual. I dont need a shop to install lights for me.
as long as your not bright purple you should be under the radar so many cars have them now...
Bob, I demand more pictures of the front of your truck with your lights you've got there....!
haha I know I will have to post some up I remember seeing your old avatar on another site with almost the same amount of lights! I will get some up soon
