Max Attitude
Typical White Person
Going to put on the cognito upper control arms. I loosened the nut on the factory ball joint and popped the ball joint loose with the pickle fork. Well i didn't loosen that nut enough before I popped the ball joint loose and now the nut spins with the ball joint shaft. The end of the ball joint shaft is round unlike a tie rod end. I tried my small pair of vice grips on the shaft but they just slip no matter how tight I lock them on. What now?
