Acesneights1
Anybody know if a 361 uses the same distributor as a 360/390 ? My F600 is backfiring like mad when decellerating. Carb is brand new. Vac advance on the dist is bad so I plugged the line Suspect that is the problem. It has points so want to put a later model electronic dist from 390.
