Hi, I have been lurking for a while, and reading up on the 6.2/6.5 platform, and am ready to finally swap one into my 84 k5 blazer. The problem is that I have too many engines to choose from...my uncle is a bit of a hoarder, and likes to buy military surplus stuff, so in his yard alone I have free rein at running m1008/m1009 engines, an 87 hummer 6.2, an 06 center mount 6.5 that were not sure if it runs, and a 98 civilian k3500 6.5turbo that has 12k on it...was supposedly hit by lighting and parked, doesn't run, but theyre are no burn marks anywhere on the truck, so mechanically it could be fine.
Anyway, I want to put together one engine, most likely with a turbo for my blazer, obviously the 6.2 in a m1009 is the easiest because literally everything is there, but I was looking for the forums help to put together the best combo, ie 6.5turbo heads on 6.2 block, I don't plan on towing anything huge, I only have a 4x8 trailer, and its not my daily so I'm not looking for necessarily the best MPG money can buy, just a cheap/free project to make my blazer a diesel. I also have a t3 flange turbo off of a cat 3116 engine that will probably do just fine, since I know the gmx turbos are not that great.
