Rodd
Recruit
I was out tonight and couldn't get my heater or defroster to blow warmer than luke warm. Cold works just fine. It is only 47 degrees out. The rear air blows hot w/ no probs. Where do I look first?
Does it blow lots of volume, but only warm? If so you need to flush your heater core.
If it does not blow very good, you may have a diverter flap stuck half way between hot and cold, or the heater core or ac coil are gunked up.
If it is the heater core why is the rear working and the front not? Where is the heater core? Isn't it connected to the cooling system (coolant)?
The heater core is just inside of the cab, and the ends stick through the firewall for the heater lines to attach to. It is on the pass side near the ac condenser. Follow the line that attaches to the t-stat crossover and it runs to the heater core. IIRC, on the suburbans, the line has a T in it that runs to the rear heater.
You have 2 heater cores... the hot coolant comes from the engine, through a T-valve to separate it into front and back, and the hot coolant flows to both heater cores. If the heat controls are 'on', then the hot coolant flows THROUGH each respective core, then back to the engine.
At each point, you have a diverter that decides whether the hot coolant goes through the core or not (possible problem spot) controlled by a thermostatic switch (possible problem spot) and each core itself is a possible problem spot. Also, air has to go through the core, and that's controlled by a flapper, so air volume is also a possible problem spot.
As Jody mentioned, the switched AC valve is also a possible issue.
Trace the flow, look at each spot, and isolate your issue. If the hose going IN to a core is hot, and the hose coming OUT isn't, the core is a problem. If the line is hot on one side of a valve and not on the other, the valve (or the controller) is a problem. If you don't have enough airflow, the flapper (or servo) is a problem.
The fact that your rear heat is fine tells us your thermostat and waterpump are OK, and that you don't need a rad cover, so you're half-way there...
tell ya what... cut up a beer box, use it and some nylon zip ties to cover up your grille and restrict the airflow into the rad.
If the problem goes away, you know that your thermostats are sticking, and you have a choice... you can fix them, or keep drinking beer so you can replace the box when it gets wet and ratty-looking.
I know what I would choose
JiFaire,
I don't even have a problem with my heater but I've chosen to follow your advise and cut up a beer box and drink some beer. Is this like preventative medicine?
Hey Dan... it's Dr. Faire...
Take 2 MGD and call me in the morning
Your heater may still blow cold, but you won't feel it. If the feeling starts to return, repeat the prescription as required.
Us Canucks know how to deal with cold
