headlight
gearhead
Harley Man
99 power stroke: how do you get the headlight out? the hole headlight Assembly that is
post a pic i will kno more.i take out all kinds of headlights just cant recall what that one needs.ford is the hardest to remove.remove the 2 clips on the top then reach down behind the light and you will see a plastic knob squeez that together and the light should come out toward you.also undo the light bulb harness.try not to bend those 2 clips or they will be hard to put back
thanks. cant take a pic because it is 30 miles away. same light on the 99 to 03 superduty's
