Well heres the issues guys, I just picked this truck a little over a month ago. It was warming up on day, i got in the low coolant was on. I added coolant. Well since then i have had to add coolant to it, Maybe a gallon and a half in 2 1/2 weeks. Well last week i was looking around for a coolant leak. Just happened to pull the oil fill cap off, there was some condensation, tasted it, yup coolant. Changed oil Monday and didn't really see any signs of Water/Coolant. Oil samples were sent off and waiting for results. Here is what i know. I cannot find a visible anywhere. I don't smell anything from engine compartment, cab or from the exhaust. I have not overheated nor run hot. I have not puked coolant, nor do i build excess pressure in the system, and for the matter, not sure if i am building any pressure as the hoses don't get hard, and i can pull the coolant cap off without any problems when its up to temp. According to records injectors have not been touched. Truck is going in monday to get checked out. Am i most likely looking at head gaskets? I know Injector cups are a possibility also. Thanks for any help guys!
02 Lb7
Banks 6 gun, Exhaust, Intake
02 Lb7
