Anubis
Being fat sucks
well as the title says.
1. low coolant light keeps going on and off. Had the cooling system flushed and bled (maybe air still trapped in it?), thermostat was recently changed (well back in spring.... it was done before I bought the truck in May)
2. engine never gets warm at idle, even with the heater off. It only make heat going down the road but never gets over 160* I thought it might have been low coolant (because of the light) but I can never tell if that recovery tank has the right amount in it and I have driven it several time to Chicago an back with no heat problems.
When my Suburban (350 gasser) did this it was the fan clutch..... I could not turn the fan with the engine off. replaced it and the fan would free wheel with the engine off. go out to my truck, pop the hood I can rotate the fan but it is stiff and take effort to move it.... doesn't free wheel..... start the engine and observe the fan....... it is spinning fast with the engine and not just slowly spinning because of parasitic and centrifugal drag.
could also still be air in the system but I got no idea how to bleed it...... you got no idea how much I wish I had a radiator I could take the cap off and see down inside it.
Maybe a bad thermostat
