jmiller
Recruit
It appears that the Crank pulley needs to be replaced on my truck.
I started to notice a clanking sound in the last day or two. When I pull on the serpentine belt, I get movement.
The big question is, if the crank pulley has given up, should the Harmonic Balancer also be changed?
Second question, what's the difference between the Dorman balancer that Heath sells and the Dorman balancer that NAPA sells?
