Josh, did you go w/ brass synchro's instead of the original carbon surface type synchro's?
If they're the carbon ones, I would suggest using a gear oil explicitly spec'd for them - like the OEM spec'd Castrol Syntorq, Amsoil, or Redline's mix combo for this type synchro's.
My experience w/ other trans w/ carbon faced synchro's is they definitely benefit from the specific friction qualities of the spec'd gear oil. I've swapped in Mobil 1's synthetic gear oil into another carbon sychro trans & it shifted OK, but upon switching back to the intended gear oil, it did shift notably easier. It felt like the Mobil 1 was perhaps too slick & the sychro's didn't match gear speeds as quickly/easily.
The Castrol Syntorq is somewhat expensive, but it's not a fluid that should need replaced anytime soon.
I've read a number of trans shop's opinions to fill an extra pint (if memory serves, you might search to confirm?) beyond OEM recommended fill. They believe that 5th gear might benefit from more gear oil splash/lube. Some fill that last bit thru the top/shifter opening. Some add a pipe elbow (turned to facing upward) to the fill port, although it's apparently rather slow to fill that way.
