iamdave0887
Here Comes Chaos.....
ok i'm fed up.
Driving along the other day i started getting a ticking noise, unlike the lifter tick i've had for a while now. This sound is only when moving under power, or hte engine is under a load(hold the brakes and release the clutch slowly in 1st and it's very audible). At first i figure, exhaust leak at one of the donut gaskets perhaps. Then it gets louder and deeper sounding. Oil pressure never dropped below 35-40 psi at idle. I don't think it's an engine knock as it's only under engine load of any kind(brake torque, driving). Free rev i can't hear it and idle i can't hear it.
Now i'm like "great now what's blown up?"
I've yet to answer that question.
The other day(before this started) i was under the truck to change out the leaky oil cooler lines and i had to remove the slave cylinder to get to one of the lines at the block fitting. Other than that nothing else has been touched under the truck.
Checked the SM465's gear oil today, and it's a hair over full as the oil is a tad frothy. Seems i put in a little too much when i put the trans in. have to drain some out tomorrow.
I noticed today that when i was under the truck i saw what looked like silicone at the flange where the exhaust pipe meets the heat riser valve on the driver's side. I peeled some off as it seemed to be hanging there doing nothing. Sure enough it's silicone of some kind. This pipe and the heat riser are coated in engine oil due to a leaky valve cover(didn't use enough silicone on it i guess) that i have to seal up.
Could the oil have eaten through some high temp silicone gasket someone made? Is there even a gasket there?
Why do i always get the weird $#$#% problems??
What in the world could this noise be? Can a clutch knock when the trans is put in gear and the pedal released? Could the flywheel bolts be loose? That would cause a racket at all times no?
I'm stumped and very fed up. This truck was supposed to be my winter transportation, as it sits in my driveway while it's snowing and i'm forced to drive something else.
On the bright side i've got a few new books to read. Detroit Diesel Series 53 Service and information books from 1969 and 1970 and a "Unit Rebuilding" shop manual for the H-NH Series Cummins. I love Estate sales.
