Guys with cognito leveling kit step inside.
Will
Boobies make me happy
Mt. Pleasant, IA
What is the measurement from the floor to the top of the cab? I'd like to make sure I have plenty of room between the top of the garage and the cab. Thanks.
Thats an impossible question to answer. None of these trucks are the same. Are we talking about stock keys, after market keys, maxed out bars, 265's, or 285's?
well i may have added a inch or 2 just to be safe.I took the same chance when i installed mine.Im about 2 inches from hitting the carport roof.But yea they are all diff
Well let me add then what I am wanting to do. 1.5" rear block, reindex keys and I'll still be running the same 285s that I have now. Lowest point on my garage door is 83". This is the stance I am going for. He's a member over on DP. I need to PM him to get his measurements.
This was from when I first put the kit on.
Lets make this easy, whats the clearance you need to fit into?
Copter's roof with a Cognito 4" and 33" is @ 83" so a leveling kit would not be higher than that.
I have 2 inch blocks in the rear of mine and I run 285's also w/ the Cognito Leveling Kit and it sits at 80 inches. So you will be fine with the leveling kit and 1 1/2 inch block
