Missy Good Wench
Wild Blonde from Cloud Mt
Hello to all
New here but not to the diesel boards.
I recently started on a project of stuffing a diesel into a 92 Burb 4x4 along with a MOPAR 4 speed overdrive. (YUP you read that right MOPAR )
I tore down a "Good" 6.2 only to be met by the infamous main web cracks.
AWE S^&T
I was brooding over this issue and contemplating how to deal with it when I learned of Lock N Stich
Now many folks have posted stuff on the boards about the threaded pin devices that they make but I had not heard about the thread inserts.
Some research revealed a local rebuilder that uses these inserts and has for several years to repair the cracked outer main bolt holes.
More digging also turned up that these guys dont do the service as an "out patient thing" only what they build.
Hmmmm I looked up Lock N Stitch and got them on the phone. Not only do they sell the tooling and inserts but have a special set for the 6.5/6.2 application.
They were very helpful and answered all my questions.
The info I have gathered from users is that there have been no failures after the inserts are used to repair a cracked hole.
The Lock N Stitch insert, unlike a Helicoil is fully self contained and not a loose coil. Also the outer threads angle up like a hook and the harder the pull on them the more they try to close the crack and pull things together rather than spread things like a wedge (Normal threads)
I ordered the tooling and some inserts and then the fun began.
I could not get a block (Heavy) onto my mill table so I designed a plate and other goodies so I could do the drilling and tapping with a mag drill.
The task is easy and takes a fairly short time to dril, tap and then lock the insert.
The inserts cost about $9 each
I have lined up a buttload of blocks to fix for some local shops so I can pay for the tooling.
Here are some pix of the operation. The platform drill plate that just gives a solid work place. The insert kit. The finished hole. Now I did use a spotfacer to drop the surface of the area slightly below the original mating area to be sure the main caps seat properly.
Best
MGW
AWE S^&T
Best
MGW
