William McNett
Newbe here
I bought this 94 k1500 w/ 228,000 miles a few weeks ago, it ran fine but started hard when cold, even if the block heater was plugged in. A little easier if I step on the accelerator pedal a little. A previous owner had told me the IP had been replaced along with a bunch of other stuff. Like injectors, glow plugs, heads, .........
To check things out I hooked up GMTDScan Basic and looked at stuff. Seen an IP timing of 6.5º w/ a TDCO of -1.5º so I paid for a GMTDScan Tech licence and proceed to attempt to do a Time Set / TDCO Learn.
After checking and clearing codes.
I click Time Set the truck dies. so I restart it and try again. Try again, dies.
Then I recall reading something about 1000 rpm, so I set the rpm around 1000, do a time set on for a few seconds, turn it off, do a tdco learn for a few seconds, turn it off
TDCO is now at 1.5º, it's blowing white smoke and will hardly stay running.
