Thanks for sharing the info & to all the replies.
Here is a quote from gpopshop.com/dieselturbos.html:
"GM/Chevrolet 6.5 Diesel
Spec #'s GM-1, GM-3, GM-4, or GM-5/GM-8
GM Spec #'s 1, 3, and 4 are all interchangeable and are direct replacements for each other. GM-5's and GM-8's are also interchangeable and direct replacements for each other. You cannot install a GM-1, 3, or 4 in the place of a GM-5 or GM-8, or vice versa, without modifications. There are no advantages, as far as performance, from one spec # to the next. All of these turbos use the exact same compressor wheel and turbine wheel. The only differences in the turbos are the outward designs and wastegate actuator locations."
I'm not in any way shape or form doubting any of the info posted here that the GM 8 flows better then the Gm 4. Just thought I would disclose the source of the info that prompted my comment in my original post.
