ShawnR
6.2 to 6.5 block swap out is done, timing appears to be set and all if good.
Glow plugs light comes on as normal on a cold start, stays on for probably 12-15 seconds, start truck, wait a few minutes & drive away.
After the truck is completely warmed up and I am at cruising speed, the Glow Plug light flashes for about 1/2 of a second evey six seconds like clockwork.
I can do the one one thousand, two one thousand,...up to six and at the end of six it flashes for half a second. It did it consistently for several minutes. (I was watching it insead of the road). It only seems to do it while driving, not while sitting at idle.
I recently swapped long blocks and all sensors. The GP controller stayed with the truck and the rest of the wiring so it shouldn't have been damaged, but anything is possible.
Any thoughts? The truck is a 93 so it has minimal computer controlled stuff.
